Do you have to replace steels with clutches?
Old Nov 26, 2013 | 08:08 AM
Ev.'s Avatar
Ev.
Car: '87 Trans Am GTA
Engine: 5.7L 350cu.
Axle/Gears: Stock
I am doing my first rebuild this weekend (1987 700r4) and the kit that i bought came with everything but a new set of steels. Do you I need these to rebuild correctly? The tranny has over 100k on it.
Old Nov 26, 2013 | 08:57 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Do you have to replace steels with clutches?
Yes replace the steels also,and where did you get the kit from
Old Nov 26, 2013 | 09:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The majority of the time, steels are fine. If they look burnt or a straight edge shows them warped, they should be replaced. Measure them to see if they're still above minimum spec.
I reuse the steels in my powerglide with no problems. I did purchase some thinner ones to get more clutches into the pack.
Old Nov 28, 2013 | 08:32 PM
Pro Built Automatics's Avatar
If the steels look ok, no leopard spots or the metal looks like it has "smeared", and they are flat, you could polish them with 600 or finer sandpaper in direction of rotation. The more of a "mirror" finish, the better. Make sure that there are no nicks (remove them) in the steel clutch, which will groove the clutch material. What type of clutch material are you using in the 3-4 clutch pack?
Old Dec 15, 2013 | 01:11 PM
TexasT's Avatar
Car: K2500 Suburban
Engine: big one
Transmission: overdrive
As above if not warped, spotted or burned I'd ruff em up with a stone , Emory cloth or sand paper and reuse em. I did that to mine but was instructed to go for a cross hatch Pattern as opposed to the "mirror" finish suggested above. I also laid a straight edge across the drum in several spots, deemed it serviceable and hit it with the abrasive too.
Your call. If your budget and timetable will allow new it couldn't hurt.
Old Dec 15, 2013 | 05:28 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
I've re-used steels for two th400 builds. I ALWAYS set the clutch pack height within specs, as should all trans builders.
Reddeath210
Oct 6, 2015 08:20 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
rsrmoore
Aug 7, 2015 08:44 PM
