Advice on junk yard T5 (pics)
Old Dec 2, 2013 | 12:35 AM
AmorgetRS's Avatar
Hi, I picked up a T5 from Pull A Part today (50% off, yay!!!). It came out of a 1990 RS with the LO3 and it's a World Class from looking at the front bearing. I figured I'd pull it apart really quick to see if I wanted to keep it or return it. I have attached some pictures the guts of it with the tail housing and the top plate off. Can anyone with some experience with these take a look and let me know if anything stands out? To me it looks beautiful. I saw no chipped teeth or worn edges on any of the gears.
Thanks,
Douglas
Attached Thumbnails Advice on junk yard T5 (pics)-img_1503.jpg   Advice on junk yard T5 (pics)-img_1504.jpg   Advice on junk yard T5 (pics)-img_1506.jpg
Old Dec 2, 2013 | 12:36 AM
AmorgetRS's Avatar
Re: Advice on junk yard T5 (pics)
2 more pics
Attached Thumbnails Advice on junk yard T5 (pics)-img_1507.jpg   Advice on junk yard T5 (pics)-img_1508.jpg
Old Dec 2, 2013 | 05:41 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
It looks good. Run it.
Old Dec 2, 2013 | 10:25 AM
AmorgetRS's Avatar
Old Dec 2, 2013 | 05:55 PM
Has the classic gear misalignment wear on the clutch gear teeth; you can spot it as a sort of groove about 2/3 of the way down on every tooth, on the drive side. Compare to the appearance of the coast side. Image is attached.
In the same image, look how hard some previous driver was on reverse... ouch.
In the other image, note also how hard someone was on 2nd (to the right of the pic). Observe all the chips out of the synchronizer (aka "slider" or "sleeve"). Compare to 3rd, at the left of the pic.
That said, for a V8 T-5, it's about as good as is left; should work OK at least for a while as long as you keep it full of fluid.
Old Dec 2, 2013 | 06:09 PM
AmorgetRS's Avatar
Thanks sofa! That is a great run down, I really appreciate it.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Fox118
Sep 1, 2015 04:07 PM
neekolzun
Aug 24, 2015 04:59 PM
orange rocket
May 13, 2002 05:14 PM
breathment
Dec 29, 2001 02:44 PM
