bad rear end
Old Dec 3, 2013 | 10:54 AM
miguelc561's Avatar
bad rear end
Ok so i got a 86 camaro with 86k. Sport with a 305. Whenever i get on it i literally feel my rear end pop out of gear and my back right tire doesnt spin like it use to. I drained everything and i could tell they were kinda worn. So the pick and pull around here doesnt have mang third gens but alot of fourth. Plus fourths have 3.23 and i know they stick out one inch more. But its still pricey. Can i just take the housing with all the gears instead of the whole assembly for price purposes
Old Dec 3, 2013 | 11:15 AM
big gear head's Avatar
Re: bad rear end
The rear end can't pop out of gear unless the gears are broke. You might need to check the transmission mount.
Taking the parts out of one rear end and putting them in another requires resetting the gears. This requires setting the pinion depth, bearing preload and backlash. If you don't know how to do this then leave it alone and get a complete rear end that is ready to go.
A 4th gen rear end will have 28 spline axles. Yours will have 26 spline axles. The 4th gen differential will not work in your rear end.
Doing those one wheel burnouts is very hard on the differential and should be avoided. If you want to do burnouts then you need to install a limited slip differential so that both wheels spin together.
Old Dec 3, 2013 | 11:22 AM
miguelc561's Avatar
Damn lol. Yea if theres one thing i dont know about its that ****. My garage is basicly a shop but im better at like fabricating and motor work. So what are you recommending i do. Check my tranmy mounts? Cause this all happended after one day of gettin on it and i basiclly no longer have the one tire fire going cause it pops before it can spin
Old Dec 3, 2013 | 11:38 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: bad rear end
Pop the rear cover off and see if there are any broken parts laying in the housing.
Trans mount and ta bushing are also worth looking at.
Old Dec 3, 2013 | 11:41 AM
miguelc561's Avatar
Already did. Just some flakes. But i feel like putting new fluid made a small difference. But didnt fix it. Today ill have to get under her again and check out the tranny. The pinion gear was 100% the spider gears were slightly worn so idk whats goin on
Old Dec 3, 2013 | 11:48 AM
Car: 1971 Camaro
Engine: 427
Re: bad rear end
Spider gears means open rear. Your rear end was never a true "posi" even though it may have acted as such at times.
Check you trans mount, I bet it's broken.
Old Dec 9, 2013 | 10:49 AM
miguelc561's Avatar
Thanks guys. It was the tranny mount
Old Dec 9, 2013 | 10:55 AM
Re: bad rear end
Good, that's an easy fix.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
