Speedometer cable and non working tach...
Old Dec 6, 2013 | 09:21 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
So the PO swapped in a TH350 and the speedometer cable is non exsistant. How long of a cable do I need? Tach does not work either, it's an Accel HEI distributor. What do I need to get that working?
Old Dec 6, 2013 | 09:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Speedometer cable and non working tach...
Originally Posted by Shadyredeyes
Tach does not work
The white wire from the tacho in the engine bay hooked up to the TACH (coil Neg ) terminal on the dist cap
Should come from the harness in a similar location to the pink wire that goes to the
BATT (coil Pos ) terminal
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
marcusaw
Aug 10, 2015 08:13 AM
