T5 Flywheel Bolt size...
Old Dec 4, 2013 | 12:27 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I see the Dorman size...
7/16-20, Thread Length: .900 Inch
The ARP and McCleod ones are
7/16-20, Thread Length: 1 Inch
I prefer the higher quality ones, but why the length difference? Will they work..
Using new GM Performance Flywheel...
Thanks....
Rafael
Old Dec 4, 2013 | 12:35 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: T5 Flywheel Bolt size...
I Got for the arp ones for mine.
not sure about the extra length.
Old Dec 4, 2013 | 12:36 PM
luvofjah's Avatar
got a part #?
They actually make one that is .875, but it says titon flywheel only...
Old Dec 4, 2013 | 12:37 PM
Car: 1971 Camaro
Engine: 427
I'll get it for you this evening.
Old Dec 4, 2013 | 12:39 PM
luvofjah's Avatar
Thanks... getting my new 11" McLeod clutch n stuff ready for install
Rafael
Old Dec 4, 2013 | 07:02 PM
Car: 1971 Camaro
Engine: 427
Part number 130-2201 is what I have.
Old Dec 4, 2013 | 07:03 PM
luvofjah's Avatar
And they are bolted up to the flywheel, not just sitting in the Box, correct? Thanks!
Old Dec 4, 2013 | 07:16 PM
luvofjah's Avatar
That part number says they are pressure plate bolts.
3/8-16 in. Thread length 1 inch.
Old Dec 4, 2013 | 07:32 PM
Car: 1971 Camaro
Engine: 427
You're right.
Sorry, my flywheel to crank bolts are part number 200-2807
Old Dec 4, 2013 | 07:43 PM
luvofjah's Avatar
So those are currently holding the flywheel in place? Not just in the box?
Those part numbers do not match the ones ARP gave me, but it seems the specs do, they are the same size as the the first top ones except they are 1 inch in length. I did a search before asking, could not find an answer.
Old Dec 4, 2013 | 10:04 PM
You gotta be careful about extra length with flywheel bolts on 1-pc rear main seal cranks; you can't see if they're going in too far and hitting something. (which would be, the rear main cap) At least on 2-pd RMS motors you can see if they stick through too far.
There's also the question of whether they're shorter and use no washers (serrated under the head for example), or longer and have washers.
Old Dec 5, 2013 | 05:44 AM
Car: 1971 Camaro
Engine: 427
The ones I have say "do not use washers"
Mine are not yet installed on this engine but I have used them on other builds in the past.
Old Dec 5, 2013 | 06:32 AM
Car: 1971 Camaro
Engine: 427
The flange on my 1 piece crank measures 1 3/8" thick. Add the thickness of the flywheel,there should Bo no worries using a 1" long bolt.
Old Dec 5, 2013 | 06:34 AM
luvofjah's Avatar
I have a 91, with 1 piece r_m_s.
Old Dec 5, 2013 | 06:43 AM
Car: 1971 Camaro
Engine: 427
^ mine is a 1 piece rear main as well.
Old Dec 6, 2013 | 06:27 PM
Car: 1971 Camaro
Engine: 427
Factory flywheel bolt side by side with ARP 200-2807
Old Dec 6, 2013 | 09:00 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
When I did my swap I just went to Advanced and ordered flywheel bolts for a stock 90 T-5 car of the same year. They looked pretty similar to the one on the left, with the 12 point low profile head. The heads on the ARP bolts look kind large compared to the stock ones. They look almost twice as tall, which may be a problem if the heads contact the clutch.
Old Dec 7, 2013 | 07:44 AM
Car: 1971 Camaro
Engine: 427
The left ones are the arp bolts. Right is stock
Old Dec 7, 2013 | 07:48 AM
luvofjah's Avatar
I am going with that ARP part number. I contacted ARP and they gave me the wrong ones, for a two piece rear main seal. Yours is correct for the one piece.
Thank you for your help in this matter, Jonny Blaze.
Old Dec 7, 2013 | 07:53 AM
Car: 1971 Camaro
Engine: 427
Glad I could be of help!
Old Dec 7, 2013 | 07:58 AM
luvofjah's Avatar
FYI, those bolts that start with the 200 are the best ones they make, if they start with 100, they're not as good, but still better than stock.
Old Dec 7, 2013 | 08:09 AM
Car: 1971 Camaro
Engine: 427
I know, 200 are the pro series. I have them for my main bolts, wav loc series rod bolts, etc...
Heck even the bolts that hold the top plate on my steering box are ARP.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stangski09
Nov 14, 2015 01:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
