One tire fire posi?
Old Dec 24, 2013 | 03:07 PM
Elvis'92Bird's Avatar
One tire fire posi?
I installed a 4th gen 1995 z28 differential (i was told thats what the diff came off of) on my 1992 Firebird. It has disk brakes (which is why I believed further it was from a z28). Upon a nasty burnout , I realized my driver side tire wasnt spinning, I also heard a slight whine, maybe normal, maybe not. Doesnt make any noises while driving normal. I heard the clutch pad or pads could be worn, but I haven't heard of clutch pads in these diffs. I figured it could also be a v6 diff. Could someone tell me some probable causes for a posi rear to act as an open diff? Thaaaank!!
Old Dec 24, 2013 | 03:12 PM
Re: One tire fire posi?
I'm pretty sure I got jipped, but it's cool. 9" Ford time. Could someone shed some light on the pads, whether or not they have them and whether or not they are serviceable?
Old Dec 24, 2013 | 03:16 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Nothing to do but open it up and take it from there. What is it really? 9-bolt? 10-bolt? Open diff? Worn LSD? Got to see inside.
Old Dec 24, 2013 | 03:30 PM
big gear head's Avatar
If it's from a '95 and it did have a "posi" then it would have been the Auburn. These have cones in them, and they do wear out. When they wear out they are scrap metal. You can not rebuild them and the more they wear the weaker they get. Also, as they wear they allow the axle end play to increase, which is a bad thing with disc brakes. If this is the case with your rear end then I recommend replacing it as soon as possible with a Eaton Posi, Eaton Truetrac or Torsen differential.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Dialed_In
Aug 20, 2015 01:45 PM
