T5 problem after swap
Old Dec 28, 2013 | 08:07 AM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
91 camaro vert,originally 305tbi now, 350 tbi,swapped from a truck,wc t5..
So after swapping to the 350, the car seemed ok but then a day later the car was hard to put in any gear(grinds when attempted,but the new owner will slammmmm it in gear)..noticed a rear main seal leak,so that was addressed..now the car was driven maybe 15 miles,stopped at a stop sign,couldn't get it in gear,turned the car off,put it in first then started it..as it was cranking the car was moving,clutch fully pressed in..it made it a block further..car will not go in gear at all now..also it started making a noise after the rear main seal fix,extreme hard vibrating of the car,under acceleration,I mean hard...does it while car is in neutral rolling down the road also when revving.during this vibrating,it's also noisy as hell..any help appreciated..
Old Dec 28, 2013 | 08:36 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: T5 problem after swap
Throwout bearing improperly installed, most likely.
Rear main seal leack could have contaminated the flywheel surface and pressure plate as well. This will lead to chatter.
Old Dec 28, 2013 | 08:59 AM
irocwagon's Avatar
They said they cleaned the oil off and turned flywheel,car has to be trailered now,damn shame, I never incedious trailered it other then initial purchase...that's what I've been reading, throw out..I'm not a transmission guy,but very mech inclined
Old Dec 28, 2013 | 09:51 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Old Dec 28, 2013 | 09:55 AM
Car: 1971 Camaro
Engine: 427
If you paid a shop to do the work, they should fix the issue.
Old Dec 28, 2013 | 10:43 AM
irocwagon's Avatar
Well, no one is willing to admit fault,I sold him the car,was mech great,he wanted a 350,found one complete for 200 with all accessories ,even headers..I had to assist in getting the vehicle running,at first the injectors would dump 100% ,and no spark,I knew something was grounded or pinched,turned out they had one of the ignitin coils on backwards,anything is possible once you break the tabs off..but two different shops,he paid 350 to get the rear main seal done,a week after motor install. It's funny the mechanic said all tbi injectors are the same and no one can tune these cars,you have to use a timing gun..Wow.
Old Dec 28, 2013 | 10:45 AM
irocwagon's Avatar
Now it looks like its going to a trans shop.if the trans has to come out,I'm not helping..bad enough I had to sell my baby,now she is bing abused,also been wrecked three times since paint in November
Old Dec 28, 2013 | 10:55 AM
Car: 1971 Camaro
Engine: 427
Sounds like you need to walk away from this.
Old Dec 28, 2013 | 11:13 AM
AssaulT/A's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
[QUOTE=Johnny Blaze;5688226]Sounds like you need to walk away from this.[/QUOTE
I totally agree
Old Dec 28, 2013 | 11:15 AM
irocwagon's Avatar
I'd buy it back if it wasn't modded
Old Dec 28, 2013 | 11:24 AM
irocwagon's Avatar
Too much to replace
Old Dec 28, 2013 | 11:28 AM
irocwagon's Avatar
I hate giving up on a third gen! But I have no time to waste.
Old Dec 28, 2013 | 04:17 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
I would highly recommend not buying it, but if you are dead set on it, offer him a grand with the wheels, you could prolly hock them for at least $500
Old Dec 29, 2013 | 09:59 AM
irocwagon's Avatar
500 they'll sell for 1200$ easily,it's originally my car,I know the history of it and its rust free
Old Dec 29, 2013 | 10:00 AM
irocwagon's Avatar
Lol...he wants $7000.00 for the car..
Old Dec 29, 2013 | 11:17 AM
AssaulT/A's Avatar
Car: 1986 Trans Am
Definitely time to walk away.
Old Dec 30, 2013 | 10:38 AM
irocwagon's Avatar
Yea I did,side note this car is about to become an auto..damn shame
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
