Third Gen swap options
Old Dec 29, 2013 | 03:41 PM
Phosgene's Avatar
Currently driving a C4 but i plan to Vortec swap it pretty soon due to low compression and just in general need of a rebuild/swap
looking at getting a Third Gen to drive in the meantime and thinking about 350 swapping a third gen before i Vortec350 swap my C4
Not wanting to spend a lot of money on one and i notice a lot of the V6 and 305 cars in very good condition, wondering if i would run into any wiring issues and if they have different transmission gear ratios and/or weaker transmissions and if the final drive is any different
Old Dec 29, 2013 | 04:34 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
Re: Third Gen swap options
If you start with a V6 car, you'll need to do the trans as well. The V6 trans will not bolt to a SBC. IMHO, just get a 305 car and drive it, if the 305 runs good, swap it when something breaks.If the 305 is junk, swap away.
Old Dec 29, 2013 | 05:01 PM
Phosgene's Avatar
does the third gen V6 also use same bellhousing as the 90deg V6s in later camaros, and the Northstar
Old Dec 29, 2013 | 05:34 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
The 3rd gens use a 60* V6.
The later 90* V6s are the same bellhousing as the SBC
customblackbird
Aug 15, 2021 10:16 PM
midge54
Sep 2, 2020 07:13 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
InfinityShade
Aug 22, 2015 08:00 PM
reiderz iroc
Aug 13, 2015 04:57 PM
