Whats a fair asking price?
Old Dec 28, 2013 | 08:32 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
I have a 9 bolt 3.45 rear that is fresh, I mean new bearings,seals,rotors,and calipers. What would be a fair starting price?
It has 0 miles since freshened up. I filled it with good lube and additive, mounted it in the car, and thats where it's been since. For the record, it was freshened with good Timken bearings and seals. No cheap junk.
Thanks for you advice!
Old Dec 29, 2013 | 08:49 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Whats a fair asking price?
$700 id say , a 10 bolt goes for around 300
Old Dec 29, 2013 | 11:01 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Yes, but very few customers (only those interested in originality of their perf option car) will find it worth more than a ten bolt. You can always start high, but I'd be surprised if you got more than $400. Have to consider as well that the average buyer has no way of knowing if you built it correctly.
Old Dec 29, 2013 | 12:24 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Thank you both for your input.
Stealth, I can return the brake stuff for 350.00 dollars. I think I'll just store it incase I find a need for it.
Old Dec 29, 2013 | 02:11 PM
stealtht/a's Avatar
Yes, true that the brakes are probably the most valuable part.
If you plan on sitting on it, you can always put ads up for a high price and see if you get a bite.
Old Dec 29, 2013 | 02:52 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I put my stock posi rearend on Kijiji and sold it for 465.00, it had 42,000 miles on it and had never been touched. I hope that helps
Old Dec 29, 2013 | 05:46 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Thanks guys for all your advice. I priced it and sold it for 550.00, to a local guy. It was only on CL for an hour. It's going into a 86 SC. I told him about the forum and maybe he'll join.
Old Dec 29, 2013 | 06:44 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
that was lucky imo since you didn't replace the axles or ring and pinion.they would seem to be the high wear items to me.rotors are cheep.
Old Dec 29, 2013 | 07:10 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
They didn't need it. The axles were in great shape, the R&P were in good shape also. The bearing were in very good shape, but since I got it used and already bought the bearings and seals, I figured, I would put them in. Yes rotors are cheap, but the calipers were 115.00 each, rotors 30.00 each, pads 56.00 all adds up to 346.00 before tax.
I apologize, I used a USA standard gear master overhaul kit. BTW, it was 225.00 shipped from rockauto. I think I gave the buyer a fair deal and I only lost 75.00 dollars.
okfoz
Sep 22, 2015 03:37 PM
gta892000
Sep 16, 2015 12:37 AM
64Chief
Sep 12, 2015 08:05 AM
pimprs
Sep 10, 2015 03:34 PM
Stryker412
Sep 7, 2015 09:11 AM
