broken transmission stud for shift lever
Old Jan 13, 2014 | 04:50 PM
JessieJames's Avatar
Car: 88 Camaro
Engine: 305 TBI
trying to install b&m shifter.. to removing factory shift lever from transmission broke stud.. so now what..
look at pics..
Attached Thumbnails broken transmission stud for shift lever-transmission-lever-stud.jpg   broken transmission stud for shift lever-transmission-bracket.jpg
Old Jan 13, 2014 | 05:32 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: broken transmission stud for shift lever
ouch!
well, i guess you could weld the new lever on there if you have enough meat.
i'd weld a little, then quickly cool it off. IDK if theres a seal in there that could leak, thats why i'd be careful and cool it off quick.
you could always grind the weld off later if need be, or even get a replacement b&m lever.
i think the valvebody needs to come off to get that lever out?
Old Jan 13, 2014 | 06:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I'm surprised a red neck wouldn't have a creative way to fix this lol , The valve body does need to be removed. Watch those check *****.
Old Jan 13, 2014 | 06:55 PM
Car: 88 Camaro
Engine: 305 TBI
Originally Posted by redneckjoe
ouch!
i have never removed valve body on a transmission before.. i plan on welding it.. any one have any input?
Old Jan 13, 2014 | 06:58 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
take your time.
put some pics up when you get done.
Old Jan 13, 2014 | 07:00 PM
Engine: Lb9
Transmission: M20
Welding will work but great way to wipe out the seal. you could allways drill and tap the shaft and install a bolt with washer.
Old Jan 13, 2014 | 07:15 PM
Car: 88 Camaro
Engine: 305 TBI
hmm that that is a good idea.. what size bolt will be thick/strong enough to stand constant back and forth motion of transmission lever ?
Old Jan 13, 2014 | 07:20 PM
Engine: Lb9
Transmission: M20
All the stress is on the lever itself. I think it will be fine. Just take your time drilling the hole straight. Maybe a little blue loctite on the threads or a spring washer for good measure.mark the center with a ouch to avoid the drill bit walking first. you might want to remove the crossmember and see how much that will lower the trans.
Old Jan 13, 2014 | 07:22 PM
Engine: Lb9
Transmission: M20
As far as size I'm not sure the shaft diameter .
1/4-20 idk with a 13/64 hole
Old Jan 31, 2014 | 04:24 PM
Car: 88 Camaro
Engine: 305 TBI
welded lever
Attached Thumbnails broken transmission stud for shift lever-lever-3.jpg   broken transmission stud for shift lever-lever-1.jpg   broken transmission stud for shift lever-level-2.jpg
Old Jan 31, 2014 | 04:39 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
looks like that will work.
did you cool it off quickly?
any leaks?
Old Jan 31, 2014 | 04:50 PM
Car: 88 Camaro
Engine: 305 TBI
i didn't cool it off quickly because i didn't let it get hot. i did 2-3 second of welding and let it cool down to 50 degrees before welding again.
and no leaks so far. car hasn't been driven yet, but the transmission fluid has been topped off.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
Todd84Z
Sep 4, 2015 08:02 AM
transaero
Aug 31, 2015 01:14 AM
someone972
Aug 30, 2015 12:52 AM
