TCC lockup inoperable at higher speeds
Old Jan 14, 2014 | 08:55 AM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I took my car out yesterday for the first time since early December. Before I let it sit, the TCC lockup was working fine, but now it seems at around 50+mph the lockup does not engage. It also takes a while to shift into OD, and when it does, any variation in the gas pedal will drop it down into 3rd again. I suspect that's because the converter isn't locked. What might be the issue here? How can I diagnose it?
I had installed a Corvette servo right before I put it away, but everything still worked perfectly after. I don't know if that's part of the problem, but that might be useful info.
Old Jan 14, 2014 | 10:34 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: TCC lockup inoperable at higher speeds
3 most likely causes: pedal switch, TPS or speedometer
Check your brake pedal switch.
Use a scanner to look at your TPS and Speed as the ECM sees it when it happens. See if the ECM is commanding lock up.
Bubbajones_ya
Jul 6, 2024 08:32 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
89fast5oh
Sep 8, 2015 09:55 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
