Axle shaft diameter?
Old Jan 13, 2014 | 04:44 PM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Off the top of your heads, what is the diameter of the 28 spline axle shafts? Not the axle tubes, but the axle shafts. Can't seem to find an answer on the interwebs or anywhere else. Thanks.
Old Jan 13, 2014 | 05:14 PM
big gear head's Avatar
Re: Axle shaft diameter?
What part of the shaft?
Old Jan 13, 2014 | 05:20 PM
Oh, forgot about that. I suppose both long and short bearing part. If possible.
Old Jan 13, 2014 | 05:49 PM
You talking about a 10 bolt or a 9 bolt?
Old Jan 13, 2014 | 05:59 PM
Darn, I keep forgetting the important info. Sorry about that. The 10 bolt. The reason I ask is because I'm curious if the axles work with a GM 8.5 10 bolt carrier or LSD with the 28 splines. I would imagine they would be different, but I would love to know. 28 spline 8.5 shafts are 1.285' I think. I was thinking about doing a "pumpkin" swap. The 8.5 housing for the 7.5 and keep the factory tubes. Kind of like the 8.8 diff someone wrote a thread about. I'm crazy, I know, but very curious. The TA mount should be easy enough to fabricate.
Old Jan 13, 2014 | 08:43 PM
7.5 and 8.5 28 spline axles are the same size at the splines and at the bearing. The c clip buttons are not the same.
Old Jan 14, 2014 | 09:53 AM
Ahh ok. I suppose this is good news. Perhaps the C-Clip problem can be remedied. Thank you very much.
Old Jan 14, 2014 | 11:12 AM
The 7.5 uses a smaller c clip than the 8.5. Don't know how to get around that.
Old Jan 14, 2014 | 08:17 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i have four 28 spline axles.1991 and 2000.do you still need measurements?
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
6998poncho
Sep 25, 2015 02:56 PM
dbrochard
Sep 7, 2015 09:41 AM
