clutch master cylinder bleeding.
Old Jan 22, 2014 | 11:53 AM
barelad69's Avatar
can anyone give me advice on how to bleed my clutch master cylinder
Old Jan 22, 2014 | 09:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: clutch master cylinder bleeding.
You bleed at the slave. Some have a bleeder screw on top others dont. Either way u bolt the slave from the bellowing and hold it at a downward angle with the pushed facing down at about a 45 degree angle. Manually press the pushrod back into the slave, release and repeat until bubbles stop In the reservoir. Bolt back on and you are good to go. Do not ever press the clutch pedal when the slave is disconnected or it will be destroyed.
Old Jan 23, 2014 | 12:53 PM
irocdis's Avatar
How about the hydraulic slaves that don't have a Bleed Screw? Same way?
FormulasOnly
Jul 23, 2018 08:47 AM
camaro1185
Oct 26, 2015 06:51 AM
meeklay812
Oct 1, 2015 03:46 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
mfp189
Sep 27, 2015 09:25 AM
