168T flywheel?
Old Jan 28, 2014 | 08:00 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
168T flywheel?
I am considering use of a 168T flywheel for my 89IROC. I have a TKO trans with a lakewood bell housing and I can't see why it wouldn't work. Of course the starter would have to change and I don't know if there would be any clearance issues with my Edelbroc TES headers. Anyone using the larger flywheel? It seems the clutch choices are better and cost less.
Sorry, I accidently put this in the wrong section. I meant to put it in drivetrain.
Old Jan 31, 2014 | 05:29 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 168T flywheel?
It's a waste of time for .25" disc size gain and added weight.
Old Feb 2, 2014 | 09:48 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 168T flywheel?
I'm using a 168 tooth SFI approved billet flywheel (RAM), with a ceramic clutch. Bell housing is an SFI approved lakewood, drilled with both straight up and angled patterns. Howe hydraulic throwout bearing, connected to a -3 braided line and adapter to the factory clutch master. Starter is a hig-torque denso type with staggered bolt pattern.
I had ran hooker long tube, and SLP shorty with no header issues.
-- Joe
Stangski09
Nov 14, 2015 01:27 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
