Looking for Picture of a T5 Speedo Driven Gear
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Hi, does anyone have a picture of what the driven gear looks like. I found lots of gears online, but there appears to be a few different types. I realize that they are based on the number of teeth...this is a 21 tooth for a 3.70ish rear.
Is this the correct T5 driven gear?
Thanks.
Thanks.
Car: `86 SS / `87 SS
Re: Looking for Picture of a T5 Speedo Driven Gear
Nope. Wrong diameter. Need a 21 tooth driven?
Thanks for your help sofakingdom
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Speedo Gears Part NO
18 Brown 3987918
19 White 3987919
20 Blue 3987920
21 Red 3987921
22 Gray 3987922
http://www.ebay.com/itm/ACDelco-3987921-Miscellaneous-Part-/390715111324?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af86f779c&vxp=mtr
18 Brown 3987918
19 White 3987919
20 Blue 3987920
21 Red 3987921
22 Gray 3987922
Okay, now I am right back to where I started from.
The original gear that I quoted and provided a link for is the exact same gear that Midias just provided a link to eBay for. 3987921 seems to be the correct part number, but JMD say it is the wrong size
I used the gear I provided with that part number in both a NWC and WC t5.
Midias, did you just replace the driven gear...assume the drive gear is a 7 tooth blue already as the original rear end ratio was 3.27?
The WC transmission I added a 7 tooth drive gear to replace the 9 tooth and I added a new speedo sleeve because it came with a VSS
Code:
Driven Gears Part NO Speedo Sleeve Part NO 7 Purple 14071731 Sleeve 345215
Perfect...thanks for your time.
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Elephantismo
Feb 13, 2019 12:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
