Is there an upgrade for the t-5 that's a direct fit or close to it?
Old Feb 10, 2014 | 05:22 PM
mr_william's Avatar
Car: 1992 Camaro RS
Apologies in advance, I'm still kind of new to forums. I tried searching but nothing came up.
I'm new to working on cars. I got myself a '92 with a manual trans. I eventually want to throw a 350 crate motor in and it seems the general consensus is that the stock t-5 can't really handle too much power.
So basically my question is, is there a manual transmission that can handle a good amount of power that doesn't require a ton of modifications? Does one exist where I can basically yank the t-5 out and put the new one in?
Old Feb 10, 2014 | 05:38 PM
krazeefewl's Avatar
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
Re: Is there an upgrade for the t-5 that's a direct fit or close to it?
Start looking around here for T-56 swaps. they will be able to handle the power of a crate 350 and there are a lot of threads on doing just that.
Old Feb 10, 2014 | 06:51 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
Your gonna need the 93-97 t56. The 98-02 (LS) t56 will fit also but you will need an adapter plate so I guess that's not a direct fit, but it is an option. Especially if you find one that's already built up
Old Feb 11, 2014 | 07:27 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
If you want to keep the 5 speed there is also the option of putting in one of American Powertrain's T-5's. They are, to say the least, strong. But that's a little pricier.
Old Feb 12, 2014 | 08:05 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You could install a G force or astro racing T5. How much HP are you pushing? Are you going to be taking it to the track? There are many members who have T5s behind 350-400hp 350s that have lasted a long time but most of them are street only.
Old Feb 14, 2014 | 09:21 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
There's also the TKO500 and TKO600.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
LilHot
Aug 23, 2015 09:36 PM
