Part number for Z-bar linkage?
Old Feb 12, 2014 | 10:25 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm looking for just the cross shaft (Not sure what it's called) that goes under the master cylinder/brake booster. It goes over the ball that's screwed into the engine block on one end. Is it available anywhere?
My current one works, but it was re-welded in the past, and not exactly where it was to begin with. So I don't have as much adjustment as I should on the threaded rod that goes to the clutch fork.
Thanks in advance!!
Old Feb 12, 2014 | 01:08 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Part number for Z-bar linkage?
It's not like it's in stock at the dealer.
Just wait for sofa to join us and tell you what you REALLY need to do.
Old Feb 12, 2014 | 06:57 PM
AFAIK that thing hasn't been available for many a year now.
Better plan all the way around, is a hydraulics conversion. That's all that will work with the T-56 that you'll soon be needing anyway...
Old Feb 12, 2014 | 07:18 PM
jmd's Avatar
jmd
That's not true. I have a 1995 T56 that matches up with 82-83 F mechanical linkage and uses a third-gen clutch.
But now that I've done that, I do recommend going hydraulic.
Old Feb 12, 2014 | 07:26 PM
Confuzed1's Avatar
Car: 83Z28 HO
JMD…you must have ESPN!!
Guess I'm hoping a dealer just "might" have a dusty one sitting in a dark corner somewhere since I'm guessing not many people replace them...
Sofa - I knew you'd say that….it's been you're "standard" response for years!
Just throwing in a hydraulic clutch has crossed my mind…but then I'd need to dig up a different bell housing. Besides, I like the prehistoric old school z bar setup….and yes - I know there's a reason why they dropped them in favor of hydraulics years ago. That's why mine had already been re-welded. And if it breaks, I probably will swap to hydraulics.
As for the trans, if it does finally break, I doubt I'd go the T-56 route…more than likely i would opt for a Tremec 5 or 6 speed.
-But this T5 has held up really well since it was built 6 years ago…and more than half that time, the 400 has been in it along with the small blower….but I'm not racing the car or beating on it…much.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
