8.8 thread i cant find
Old Feb 15, 2014 | 09:20 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
there was a thread on here with a link to an ls1tech thread on a 8.8 explorer rear in a ls trans am. he ran it torquearmless, i cant find the thread on her or there and searched for a few hours. anyways anyone know which one im talking about?
Old Feb 15, 2014 | 12:11 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 8.8 thread i cant find
If its the mini-ladder bar setup, you dont want that
Go with a TA mount, they're not that difficult to build
Old Feb 15, 2014 | 02:14 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
and how come? regardless id still like to find the thread
Old Feb 15, 2014 | 03:24 PM
Pocket's Avatar
Car: 91 Trans Am
They bind the rear axle so it acts as a swing arm. Go over a bump with one wheel and not the other, then the other wheel lifts off the ground. You can even dump the rear sway bar because the whole axle is acting as one
This one started just about all 8.8 builds
http://ls1tech.com/forums/gears-axle...8-8-build.html
If you're dead set on not building a TA mount, use a MM TA that bolts to the bottom of the diff
http://ls1tech.com/forums/gears-axle...l#post17843620
More reading
http://ls1tech.com/forums/gears-axle...adder-bar.html
Old Feb 15, 2014 | 03:53 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Hmm wierd, guess ill look into the torque arm provisioned th400 crossmember. i wonder why they suck so bad on fbodys? when i solid axle the front of my 91 K150 i went with a ladder bar type setup like the rear and it worked excellent, no binding whatsoeve, drove fine turned fine but thy were also more than twice as long as those. now how would i go about making a bracket for the 8.8 i thought about something that clamps onto the both the diff cover axle tubes and flanges of the pig but i dont possess the tools to do something like that any longer.
Old Feb 16, 2014 | 09:04 AM
Pocket's Avatar
Car: 91 Trans Am
Good ladder bar setups are as long/longer than our TA and are not parallel, they cross near the trans output shaft. This allows some axle articulation
The MM TA setup for mustangs would be the easiest retrofit into a 3rd gen. Bolt it on and mount the supplied crossmember in the trans tunnel somewhere. Still need 10 bolt brackets welded on and figure out the overall width/lug bolt pattern issues
Old Feb 19, 2014 | 10:32 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i uess ill have to figure out something to use for atorque arm setup then.
Old Mar 7, 2014 | 09:21 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
hiltsy855 sells a TA saddle mount for the 8.8 housings. it's very inexpensive and works great. i used the saddle and went to a jegster tunnel mounted torque arm.
Old Mar 7, 2014 | 10:20 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Link?
Old Mar 7, 2014 | 10:25 AM
Car: 91 Z28
Engine: 6.0L LQ9
hiltsy855's build thread is over on ls1tech, should be easy to find in the gears section. my build was included in my lsx swap thread. search "husler mid-length headers", that should bring it up.
Old Mar 7, 2014 | 10:31 AM
Pocket's Avatar
Car: 91 Trans Am
Search hiltys on LS1tech, cant miss it
Old Mar 7, 2014 | 07:20 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
It doesnt show up with anyrhing
Old Mar 12, 2014 | 01:14 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
okay found it conatacted him located a 96 explorer with 3.73 discs and limited slip that i think im gonna pull the plug on
Old Mar 12, 2014 | 05:23 PM
Pocket's Avatar
Car: 91 Trans Am
Use two drivers side axle shafts and lengthen the passenger tube to match and it becomes 3rd gen width. It's a ford 5 on 4.5" pattern though
Old Mar 12, 2014 | 05:31 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
I thoight you could swap axle shafts
Old Mar 13, 2014 | 11:07 AM
Pocket's Avatar
Car: 91 Trans Am
Can and did
Old Mar 13, 2014 | 11:38 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Was.it a bad.idea?
Old Mar 13, 2014 | 03:20 PM
Pocket's Avatar
Car: 91 Trans Am
Why would it be? Putting over 600lb/ft through it
Old Mar 13, 2014 | 04:07 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
seemed like you were getting at something i just assumed, i dunno
Old Apr 25, 2014 | 02:55 AM
BenserJanes's Avatar
Yeah I agree with pocket that you can use two drivers side axle shafts and lengthen the passenger tube to match and it becomes 3rd gen width.
Clinton Township MI Locksmith
Brinkkl2000
Aug 4, 2018 08:29 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
stickychinsac
Aug 31, 2015 06:06 AM
Thornburg
Aug 27, 2015 11:34 PM
