9 bolt gears
Re: 9 bolt gears
Sure...
Any from any other 3 series 9-bolt. Or of course, from the store. No problem.
Then all you have to do, is find all the bearings & seals.
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Bunch of smart asses. Lol.
Pretty much any 9 bolt gear will fit your carrier. It's the 2 series ones that suck. Only 2.77 and 3.08 fit 2 series. You can order pretty much any other ratio for 3 series. I went with 3.70s of course I had to replace my 2 series with a 3. I think you can get all the way up to like 4.30s...
Car: 1989 IROC-Z28
Correct. OP, if you have a 9 bolt 3 series carrier there are a lot of 9 bolt 3 series carrier options. Just look. I got my Motive 3.70s with install kit from Hawks Third Gen.
Re: 9 bolt gears
The particular seal that seems to be a problem is one of the axle seals. Be REAL cautious about the idea of pulling the axles unless you already have both sides in your hand. (they're different... don't ask me why somebody thought THAT was A Good Idea...)
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
