Sudden 700r4 Issue. Loves 3rd gear.
Old Feb 22, 2014 | 06:18 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
To start off, this is an 86 model transmission that was rebuilt about 7k miles ago with a Pro Built street/strip rebuild kit.
I drove the car Thursday and Friday and it acted like it has since the rebuild. I started the car up today, pulled to the top of the driveway then noticed something different. When I pulled out onto the highway it felt like it suddenly made the 2-3 shift and felt like it was lugging in 3rd gear. I eased up on it (long downhill from there) and it was driving fine but that had made me uneasy. I found the the first turnaround and stopped. Trans downshifted normally. I started back towards the house and the 1-2 shift felt softer then normal but at about the same point. But the 2-3 shift was early.
My first thought was TV cable. So I checked it. It hasn't changed. At WOT it is still at full travel. Nothing changed on it. So I checked the fluid level. Havent noticed any leaks, but it was about a pint low. Topped it off and went for a short drive. Started off fine, Pulled out in first gear, hit second, went to third, felt almost like normal. Then I turned around. Trans downshifted fine. 1-2 shift was close to normal, but 2-3 felt different. Instead of the normal bang-shift at the same time, it felt like shift, bang. I know that may sound odd, but that's how it felt. Then it was in 3rd gear and didn't want to downshift until I was almost at a full stop. Once at a full stop, I punched it in first, it smoked the tires, hit second still smoking them, then I let off and stopped. Then I start to park it and at less then 10 mph it shifts to 3rd and lugs. I stop and it downshifts back to first. Then I park it.
Im completely lost right now. Any insight? TV cable is good. Fluid level is good. Maybe something broke or stuck in the valve body? I don't see how anything could have happened to the shifter, but I wont rule that out, maybe the adjustment somehow changed? Im completely lost and any help would be appreciated.
What really gets me is that I drove it the last 2 days and it drove as it always has. Then today as soon as I pull out of the driveway something acts different.
Old Feb 23, 2014 | 12:09 PM
3rdgenmaro's Avatar
Car: 88 IROC
Re: Sudden 700r4 Issue. Loves 3rd gear.
Debating on driving it a short distance by shifting manually to see what happens. Not really sure what that will show though. Im blind on this one. Just going with it.
Old Feb 25, 2014 | 05:41 PM
3rdgenmaro's Avatar
Car: 88 IROC
Where is the delete button? Im an idiot. Had a failure in my lockup circuit and the torque converter was staying locked except for when the brake was applied. So what I thought was 3rd gear was actually 2nd gear from about 5 mph with the converter locked. I thought it felt like a straight drive...........
Old Feb 26, 2014 | 11:24 AM
Pro Built Automatics's Avatar
Give me a call later today and lets see what is going on here. Dana
Old Feb 26, 2014 | 11:43 AM
3rdgenmaro's Avatar
Car: 88 IROC
Thanks Dana, but I determined it was an issue in the lockup circuit. Mainly some dummy that accidently mispositioned a switch.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Strick1
Sep 6, 2015 02:21 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
