TH350 reverse manual valve body?
Old Apr 7, 2014 | 04:26 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hello,
I picked up a TH350 for my track car. It's got a manual valve body, and a transbrake. The seller said he thought it was a reverse valve body. (but he couldn't remember).
Any way of telling before I install the transmission?
I'm sure I can put it on the lift and run it under throttle in each gear and watch the speedo, but I'd like to configure my shifter before I test run it if possible?
-- Joe
Old Apr 7, 2014 | 07:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: TH350 reverse manual valve body?
There's no way to tell if you have a forward or reverse pattern valve body without some way to run it up. You need oil pressure in the hydraulic circuits. Install it in a car or find someone with a transmission dyno.
There are very, very few TH transbrake valve bodies in the forward pattern so assume it will be PRN123
Old Apr 7, 2014 | 09:09 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hrmm. It's got a hughes transbrake, so I'd assume they just used a huges valve body. I wonder if their is a part number cast into the body.
I'm trying to figure out if I can use my Hurst Quarter Stick shifter with the reverse valve body. I'm thinking no.
Trans came with a SFI bell housing. It's old though so probably needs recert, but I think it's only required 10.99 or faster.
-- Joe
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
mizz0313
Aug 12, 2015 06:45 AM
