Electronic Speedo - Mechanical, just swap tail housing?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I'm about to send my transmission off to be rebuilt, the kit came from Dana at Pro-built. My question is, the new transmission is an 88 700R with provisions for an electronic speedo...it also wasn't out of an F-body car. Can I simply swap the tail housing from my 84 model, complete with mechanical speedo gears onto the newer tranmission or will there be more work involved?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Electronic Speedo - Mechanical, just swap tail housing?
You'll have to swap the tailshaft housing anyway if you need the stock torque arm mount. Otherwise the electronic sender and mechanical sender pretty much interchange. You may have to swap the internal speedo gears, if they are different.
Before swapping tailshaft housings, be sure to install a new bushing and seal in your 84 tail (or stick your housing on the tranny before sending it off).
Car: 1984 Trans Am
You'll have to swap the tailshaft anyway if you need the stock torque arm mount. Otherwise the electronic sender and mechanical sender pretty much interchange. You may have to swap the internal speedo gears, if they are different.
Before swapping tailshafts, be sure to install a new bushing and seal in your 84 tail (or stick your tailshaft on the tranny before sending it off).
Can the tailshaft be swapped after the rebuild or does it need to be done while the rebuild is happening?
Swap it out after the rebuild, no problem. Just keep the seals needed for the tailshaft housing and install them before swapping. Should have a large o-ring for the tailshaft housing to tranny, small o-ring for the speedo cable input, o-ring for the speedo housing, rear yoke seal and bushing. I may be missing one?
Pull off the 88 tailshaft housing and you should be able to identify all the needed seals except for the speedo cable input.
When you get the rebuilt one back you'll have to check the speedo drive gear, which is installed on the output shaft. Make sure it's the same as your existing one. If not you can swap them over easily.
Car: 1984 Trans Am
ambainb
Apr 25, 2016 09:21 PM
