4th gen rear swap!
Car: 89' Bandit 2 #104 of 500
Engine: LS1 5.7L
Transmission: 4L60e
Axle/Gears: 3.23 posi
4th gen rear swap!
I cant find a clear answer??? i have 89 firebird and i swapped in a 4th gen posi rear, and i want to know if i still need to run 2inch spacers or spaceers at all? my rims are c6 zr1's 18x9.5. i think my off set is 56mm or 40 mm?!?!
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 4th gen rear swap!
i swapped in a 2000 rearend.im running 18x9.5 y2k corvette wheels.they clear everything except when i jack up the rear of the car and let the rear hang.then the drivers side wheel catches on the bump stop.the 1993-1997 rearends are a little wider.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
