Slave Leaking? But reservor is still full
Old Apr 30, 2014 | 10:20 AM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Just finished my ls1/t56 swap and have a concern. After bleeding the clutch, the car drives fine. However I have alot of brake fluid leaking where the bellhousing meets the engine block. The weird thing is that I still have the exact same amount of fluid in my clutch master reservoir, as if im not losing any fluid. Could it be that I have a "puddle" of fluid sitting in the bellhousing from the excess fluid that leaked while bleeding the clutch? Or is the slave definitley bad? I have only driven the car 11 miles, and it has been leaking for 3 days. I'd hate to yank the trans for no reason.
Old May 1, 2014 | 11:07 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Slave Leaking? But reservor is still full
Do you have a speed bleeder installed or are you using the stock stub?
The stock stub allows the fluid to pool at the bottom of the bell and leak out over time
Pop a cover off and spray liberally with brake cleaner if it bothers you
It's not a leak if there is no change in fluid level. Ls1 hydraulics don't move much fluid so you should notice even a small leak quickly
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
ericjon262
Sep 11, 2015 06:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
