Rear end help, trying to decide what part of what I read is true
Car: 2004 Chevy Malibu/1988 Iroc Z
Engine: 3.5 v6 Malibu, and 305 camaro
Axle/Gears: 3:45
I have the 10 bolt rear, 3:42, or some similar aftermarket rear judging by my rpms. I am building a moderate vortec 350 and wanna know what the 10 bolt can handle? I've read on it, and I get mixed results in regards to the durability of this rear end. Any input? And what's the spline count for the ones in the IROC's, as I understand 2 different versions exist. Thanks!
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Rear end help, trying to decide what part of what I read is true
The spline counts were not dependent on the engine or trim package(RS/IROC/Z28) of the car. All cars had the 26 spline axles till 88 or 89, I believe it was 89, and cars made after that got the 28 spline axles.
As for power handling, it depends on what you do with it. 350-400HP is usually safe, unless you are running slicks. Abusing the rear end will also break it, as with most things.
Some guys have broke them with a stock 305 and others have run over 400 HP and they survived. It's impossible to say what it will handle, but most of the time if you only use hard street tires and don't have any wheel hop they will hold up pretty well.
Axle/Gears: 3:45
Hmm, interesting, thanks guys!
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I'd say with an automatic trans and street tires, you will be just fine.
hectre13
Dec 11, 2023 08:14 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
