is my st10 strong enough behind my new engine
Old May 5, 2014 | 08:07 PM
trevorsmith82's Avatar
Car: 82 Firebird/ 79 Camaro Berlinetta
Engine: 151 Pontiac Iron Duke TBI/ 305 SBC
Transmission: THM200/ THM200r4
Axle/Gears: 2.93/ 2.41
i would ask this on nastyz28 but im have trouble with the site but like always im sure someone on here could enlighten me
my 79 Camaro I have decided to completely redo and drop a 4 speed manual in
problem is I have a st10 from my dads 78 z28 but is it strong enough behind my new 350 vortec I don't know what its putting out but specs are stock block howards cam 214/214 @50 447/447 double roller chain performer rpm intake 600 carb full length headers true duals/xpipe
secondly off I think it has a 2.63 first gear will that work ok with my new 3.73 gears
thanks you everyone I know I don't have a third gen anymore but im grateful for anyones help
Old May 9, 2014 | 03:48 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: is my st10 strong enough behind my new engine
I don't know much about the super T-10 but I've seen a guy put down 450 ft lbs to the wheels on a dyno through a stock T5, and I'm pretty sure the old T-10's are stronger. A bigger factor is how your drive it. If it was mine, I wouldn't worry about it much, especially if you stay away from slicks and 5k clutch dumps, etc.
Old May 9, 2014 | 08:01 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
I'm currently putting 550+ ft lbs into a Muncie M21 which is similar in strength to a ST-10 and have no issues. Granted I don't drag the car but I do get into it quite a bit and have fun with it.
3.73s with a 2.63 first will be a little much as 1st gear will basically be useless. You could basically start in 2nd gear all day. The 2.63 1st is more suited for a 3.23 or 3.42 rear gear. On the plus side the high gear will will take a little strain off the trans.
Old Jun 4, 2014 | 12:04 AM
JIsaacs's Avatar
Car: 87 Camaro
Engine: 350cid
Transmission: BW ST-10
Yeah it'll hold up.
specialized
Jun 18, 2022 09:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
Catcher55
Aug 15, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
