Firebird Rear end-posi swap
Hey everyone. Well today I we my rear end in my firebird. It is a 350 swapped firebird that originally had the v6 in it. So I'm assuming this rear end is garbage anyways. I have an appointment with the transmission shop on Monday for my transmission rebuild... So I Midas well get the rear end fixed and made posi... Or something like that.
Either way I want it to be posi... As I plan on building it further. The transmission is getting a beefy build and should be good for a while.
What should I tell the transmission shop to do with my rear end!!? I want it posi.... But I don't want to spend more than $1200 or so for whatever they gotta do. If need be I can get a salvage unit to swap in... What do I look for?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Firebird Rear end-posi swap
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the v6 and v8 rearends are the same except for the gear ratios.im running a v6 rear because i wanted 3.42 gears.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
