83 Camaro Speedo Cable from cruise to trans
Old May 13, 2014 | 04:35 PM
Bob63's Avatar
Hello everyone. Wondered of someone could steer me in the right direction.... my speedo cable just broke , the one that runs from the cruise control module to the transmission . Can someone advise who carrys them. thanks in advance ! Bob
Old May 13, 2014 | 05:21 PM
Re: 83 Camaro Speedo Cable from cruise to trans
AutoZone, if all you need is the inner.
Thing is, there's A REASON WHY it broke; and just swapping it out, won't provide more than a temporary fix. Either the upper cable needs lube, or the cruise regulator is farkled. Find out which, and fix it, otherwise replacing the cable is a waste of time.
Old May 13, 2014 | 08:14 PM
Bob63's Avatar
Damnit no Autozone in Ontario will check Auto Value.... ya was thinking that cruise regulator may be done.... have a few more around here I'm sure ... will get to the bottom of it and Locate a cable thanks for the reply =)
Old May 14, 2014 | 07:00 AM
If they have Dorman's Help! line, you should be able to find it.
Easy enough to try to spin the regulator by hand and see if it's binding. Also, pretty easy to lube the upper; just pop the cluster out and pull the inner.
Old May 14, 2014 | 07:47 AM
Bob63's Avatar
Thanks for the info my friend !
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
colton_carlson
Mar 8, 2019 12:21 PM
beachrodder
Aug 7, 2015 04:27 PM
