T56 throw out fork question
Old May 16, 2014 | 07:48 PM
mt91ta's Avatar
Car: 1991 Trans Am
Engine: Supercharged 383 stroker
Axle/Gears: 4:11, 12 Bolt
I have a 383 (350 w/ 400 crank), running a Quiktime 6022 bell housing. The 6spd I'd from an '07 Camaro. I was looking at the throwout fork and the factory T5 one appears too long and the T56 one looks to be the right length but won't work with my throwout bearing. What throwout fork should I use? Also does anyone have a copy of Keisler Engineering installation directions? Thank, Mike
Old May 17, 2014 | 08:22 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: T56 throw out fork question
Camaros were not built in 2003-2009, so an '07 trans is not from a Camaro.
T56 from behind an LT1* used a hydraulic master/slave to a conventional fork, to a "reverse", pull-style clutch. *LT1s were in Camaros from 93-97.
Anything else used a hydraulic throwout bearing. No fork involved.
QuickTime 6022 - this bellhousing is for a 4 speed. You needs something different to run a T56.
Old May 17, 2014 | 02:29 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
First off, ignore anything Keisler. They were a questionable entity when in business and no longer are anyhow.
Second, you're throwing out years and parts that don't work together without additional parts changes or significant modification.
Slow down, quit expecting a 30 second solution to all things T56 swap and post pictures of what you actually have in-hand. That will allow others to help.
Ghettobird52
Apr 21, 2020 08:44 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
rsrmoore
Aug 7, 2015 08:44 PM
