89 700r4 won't shift past second gear..
Old Aug 25, 2013 | 09:47 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I have an 89 Iroc 305 tpi with a 700r4. It will only shift to second gear. Reverse works fine but when you put it in drive or overdrive it will only start start out fine in first gear shift normally in second and simply remain in second, it doesn't attempt to upshift at all but will downshift into first and upshift back into second... any ideas as to what the issue could be? I have the trans out of the vehicle and plan to rebuild it, just wondering if there is anything I should expect to find or if there is any reason to look for another to rebuild..
Old Aug 30, 2013 | 04:20 PM
91z28ss's Avatar
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Re: 89 700r4 won't shift past second gear..
Have the same problem here! I have been told from a GM technician that it needs a complete rebuilt, apparently it would be a band failure but the trans has to be opened for further investigation...I am thinking of the idea of ordering a bullet proof trans instead of messing around with the OE trans for the 4th time now!
Old Sep 1, 2013 | 07:58 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i had a 84 700r4 that the plastic gear on the governer stripped and caused this.
Old Sep 1, 2013 | 08:03 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Mine was also stripped but it wouldn't shift to second gear. It didn't shift at all, cost me less than $5 on ebay and it works fine now.
Old Sep 2, 2013 | 02:50 PM
89RsPower!'s Avatar
Hrmm couldn't cost anything but time to check, something cheap would be nice.. I'll let you know what I find
Old Sep 2, 2013 | 03:35 PM
zenish's Avatar
Engine: 305 tbi
As I remember I had the pry off a side cover and it pulled right out but my memory sucks....seems like its harder to put back in...seems like you have to make sure something's not out of place.
Old May 13, 2014 | 11:27 PM
89RsPower!'s Avatar
well no such luck, gear is just fine..
Old May 17, 2014 | 04:10 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Mine just went out too. It was the 3-4 clutch pack first. Now I gotta find a new one
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
someone972
Aug 30, 2015 12:52 AM
kyle5647
Aug 7, 2015 03:08 PM
drathaar907
Aug 6, 2015 04:20 PM
