Howling noise!
Old May 17, 2014 | 05:44 AM
Pshnmeawy's Avatar
Howling noise!
I have a TH350 and a Rear end setup from a 02 which has been completely rebuilt by a speed shop. Now even before the rear end was rebuilt I've always had this howling noise from the center/rear of the car. I've got the car up to speed then killed it in neutral and it does not make the noise. The noise is only present when I press the gas pedal and moving. I also replace all my U joints.Could it be trans related?
Old May 17, 2014 | 07:44 AM
Re: Howling noise!
No
Sounds like pinion bearings
Old May 17, 2014 | 08:50 AM
big gear head's Avatar
Re: Howling noise!
Pinion bearings or possibly the gears. If the rear end was rebuilt using the same gears, and you had the same noise before and after the rebuild then I would say the gears are bad.
Old May 17, 2014 | 09:28 AM
Re: Howling noise!
Of course it also depends strongly on what "completely rebuilt" means... it's not like there's some universal "list" of what that consists of.
Sounds to me like if "completely rebuilt" didn't even AFFECT it, then someone's concept of "completely rebuilt", is VERY DIFFERENT from mine.
Old May 17, 2014 | 10:41 AM
Pshnmeawy's Avatar
Re: Howling noise!
Well I mean the rear end was completely swapped out to freshly rebuilt one. Axle and all(Came from 02).. I really wanted disc in the rear. And before the swap I had the same tone "howl" as I do in the new one. I reused none of the parts from the old one.
Old May 17, 2014 | 12:37 PM
Re: Howling noise!
It could be coming from the rear end, but I would look somewhere else if it's the same noise.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
64Chief
Sep 12, 2015 08:05 AM
Randomtask2
Sep 7, 2015 05:06 PM
