t5 to TKO600 swap
Old May 29, 2014 | 12:59 PM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
t5 to TKO600 swap
Do I get the Lakewood bellhousing or order the adapter kit from fortes? What's the better idea money wise and mechanically? Any other changes i'll need? I have a 87 305 IROC
Old May 29, 2014 | 01:15 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: t5 to TKO600 swap
This should help, I found it with the search feature
https://www.thirdgen.org/forums/tran...-tko-help.html
Old May 30, 2014 | 10:04 AM
Car: 1987 IROC Z28
So I just ordered from Forte's and I understand he is sending me the FORD TKO600 because it has a longer input shaft, and that's how he does his conversion kit to match up with the original T-5 bellhousing...
My question is...
When the time comes to swap in a 350 or 400 SBC years later, will this input shaft not match up? Will I need to get the CHEVY TKO600?
I know a ton of people do this swap and it's been successful and everyone raves about it. I am just worried about the future...
Old May 31, 2014 | 10:29 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
My question is...
i assume you are putting this in the 305 you have now. if you are getting whatever you need from forte to get the ford shafts to work with the 305, it will work with whatever other small block you put it behind as well
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
