17 degree trans offset, can i put a trans straight up?
Old Jun 1, 2014 | 11:48 PM
chiz420's Avatar
Car: 1991 RS
Engine: 383 stroker
Transmission: t56
I have a 91 camaro that im installing a t56 into. I have a weir bellhousing and it sits the trans in the nomal upright position, instead of the 17 degree position on our cars. Btw why is it athat way anyway? I looked all over and found very little info on it. So i want to know you guys opinion on using it. My buddy owns a shop and i can have him drill and tap the 17 degree in, but why if i dont have to. Anybody try it this one before???
Old Jun 2, 2014 | 01:29 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 17 degree trans offset, can i put a trans straight up?
It was a way to put the shifter position in a similar lateral placement as the 4 speeds before it.
The T56 shifter position isn't in a bad place.
So . . .why the Weir?
Old Jun 2, 2014 | 01:58 AM
chiz420's Avatar
Car: 1991 RS
Engine: 383 stroker
Transmission: t56
Im using the weir cause no bellhousing came with the trans and the stock t5 i had seemed like a dinky pos to strap to a 500 hp 383. I got 11 in mcloud clutch set up, a new input shaft and t56 midplate with hydraulic throw out on the cheap. Couldnt say no. Im guessing ill have to shim the sphon crossmember to get it straight and im sure the shifter will be a lil off center.
Old Jun 2, 2014 | 11:47 AM
jmd's Avatar
jmd
You'll trim the floor to the rear.
I have an LS T56 to sbc fix that I might want to run past you in a few days.
Old Jun 2, 2014 | 12:31 PM
chiz420's Avatar
Car: 1991 RS
Engine: 383 stroker
Transmission: t56
Sure anything i can do to help ill be happy to, also can u be a little more specific on the floor cutting??? Thnx
Old Jun 3, 2014 | 07:48 PM
jmd's Avatar
jmd
On a T5 car, you shouldn't have to cut anything laterally. Just further towards the rear.
Cut it after the trans. is in and suit the opening to your shifter boot / shifter handle / console.
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
