9 bolt axle info needed
Old Jun 3, 2014 | 09:49 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Hey guys,
Im refitting a diff that has 9 bolt housing ends and aftermarket axles but the seals are no where near close enough to slide over the seal area of the axles and if I try to press these things together the seal is going to split. I have verified that the seals are correct so before I contact the axle manufacturer I would REALLY appreciate it if anyone has a stock GM 9 bolt axle removed if you could measure the landing where the seal rides and post that size? That would be a big help so I can reason with knowledge instead of guesses.
many thanks
IROCZ1989
Jan 24, 2016 03:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
