Best shifter for tko600
Old Jun 9, 2014 | 04:50 PM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
For the love of God can someone please advise on the best shifter for my 87 IROC. Just had a TKO600 installed.
By best I mean:
Best fit, no fabrication to the console and/or shifter (direct fit)
Shortest Throw.
The threads I have searched for on here... no one ever seems to give a definitive answer. What should I get? What are you using? I want something that looks and shifts great, but with no more fabrication to the console or floor pan! Thanks!
Kent
Old Jun 19, 2014 | 03:05 PM
Car: 1987 IROC Z28
Re: Best shifter for tko600
bump... the stock handle that goes straight up and down doesn't clear my console. At this point instead of buying another shift stick offset at 30 degrees should I go steeda or pro shift 5.0?
Old Jun 20, 2014 | 12:41 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i put a steeda tri ax on mine, i had to modify the handles somewhat to get it to sit where i wanted it, i believe it hit also, nothing will drop in and fit
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
