Which tranny do I have
Old Jun 18, 2014 | 08:26 PM
transamman83's Avatar
Car: 83 Trans am, and 91 Camaro
Engine: both have a 305.. For now
Quick question. How can I tell what tyranny I have. 83 trans am automatic stock 4 barrel.
I restored the car pulled engine and tranny and went through the engine. That runs strong. Now when I go to drive it and give it any gas it bogs down and shifts weird,I've only. Driven it a couple miles. I did notice that when I checked the fluid with the car hot and running fluid didn't even register on the dip stick. Father in law said he filled it. Guess I should have done it myself. Any tips? 75k original miles.
Thank you.
Old Jun 19, 2014 | 04:49 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Which tranny do I have
I believe it's a 700R4. Make sure to check it hot and in neutral. If it doesn't register, fill it 1/2 quart at a time, shift thru all the gears slowly, then back to neutral and check it again. Repeat that until it reads where it should.
Old Jun 19, 2014 | 03:24 PM
http://i199.photobucket.com/albums/aa243/transamman78/017-Copy.jpg
Any way to tell by looking at this?
Old Jun 19, 2014 | 03:25 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
GM specifies that the fluid be checked in Park and not neutral.
It probably doesn't change the fluid level reading on the dipstick very much, but in Park the low/reverse clutches are applied (nothing is applied in neutral) so there is fluid flowing in that circuit.
Old Jun 19, 2014 | 08:32 PM
http://i199.photobucket.com/albums/a...8/017-Copy.jpg
Car has overdrive. So i'm assuming it's a 700r4?
Old Jun 19, 2014 | 09:42 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Yes.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
