Rear end help
Old Jul 4, 2014 | 09:50 PM
Formula2208's Avatar
Rear end help
1989 firebird formula 350. what is stock gear ration in the rear end and what gear oil should I use when I change it?
Thanks!!
Old Jul 5, 2014 | 12:47 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear end help
You can either use 80w90 or synthetic 75w90. Either will work just fine.
Old Jul 5, 2014 | 02:26 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Rear end help
There's a tech data section on the front page of the forums that list the different rear axle ratios depending on engine/transmission combination you have. This is no guarantee of what the actual ratio is in your particular car; the rear end or gears might have been changed at some point.
https://www.thirdgen.org/1989-pontiac-firebird
You're going to have to remove the differential cover to change the gear lube. While the cover is off, you can count the pinion and ring gear teeth to determine what gear ratio you have.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
