87 700r4 into 86 car
Car: 86 Camaro
Engine: 305Ci
Transmission: 700r4 w/ shift kit
I have an 86 camaro sport with a bad transmission. I purchased a working 700 out of an 87 Iroc. Is there anything different about the transmissions? I know that my car had mechanical speedo and this one has electric. Other than that, is anything different? or will it just mount right in?
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Re: 87 700r4 into 86 car
Axle/Gears: '01 3.42 10 bolt
no ned to do anything with the shaft. the iroc has a mechanical set-up just like the '86. all you have to do is swap the speedo gears and housing to make sure you have the correct ratio. the vss on the iroc is behind the speedometer in the gauge cluster. everything up to that point is mechanical.
Iroc8t8
May 4, 2026 08:09 PM
