stock left/right axles the same?
Old Aug 16, 2014 | 06:51 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
hey all,
so i was putting the rear end back together on a 91 camaro i have....i had both axle shafts out and know that the left and right side are the same length and what not.....BUT it seems like the right axle is sticking slightly farther out than the left when looking at the car on the ground...it's for sure noticeable.
Someone told me that the left versus right axle have different thickness on the wheel flange (the part that the wheel studs go into). Is this true or is this person blowing a bunch of smoke? The car is lowered with a stock panhard bar and should be pushing the left side out just a little bit more than the right.....but for sure has right side out more.....probably something like 3 or 4 mm. Ive never noticed it before and noticed this right away. any thoughts?
Old Aug 16, 2014 | 07:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: stock left/right axles the same?
The 10-bolts are the same and interchangeable.
9-bolts had different lengths.
Old Aug 16, 2014 | 08:00 PM
big gear head's Avatar
10 bolt axles are exactly the same length. There is no right and left. The problem you are having is something to do with the bar that locates the rear end under the car. May be bent or maybe the bushings are worn out. You can get an adjustable bar.
Old Aug 17, 2014 | 06:09 AM
Engine: L98 494hp
that's what i thought....thanks guys. ill check the phb.
customblackbird
Aug 15, 2021 10:16 PM
Genopsyde
Oct 7, 2015 08:35 PM
draco
Oct 4, 2015 09:25 PM
red90IROCls1
Aug 25, 2015 06:56 AM
