T56 Clutch Pedal mod
Old Mar 21, 2012 | 08:23 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
This is a pretty popular subject these days. I have read the best option is to purchase 4th gen pedals and hack off the gas pedal. I was a little more budget minded and opted to modify my original clutch pedal. The point of the pivot bolt is to make it adjustable so it can be fine tuned. I got lucky and where I put it is right on the money. I planned on welding it solid after I found the sweet spot. I hope this helps some people.
This is how it is stock.
Drilled a hole through it to make it pivot
Cut it off
Pivot bolt
Grade 8 bolt with shoulder cut to length and drilled for cotter pin
Welded it to the arm from the backside. My first time welding so it looks like crap but it is plenty strong.
I realized my pivot bolt head would be in the way of the master arm so I ground it flat and tacked it to the pedal
Installed in car.
Old Mar 21, 2012 | 08:43 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T56 Clutch Pedal mod
Way to add to the options for those doing a swap.
What would add to your write-up IMO is measurement of original stud centre to pedal pivot centre measurement and distance of the new position as well.
Old Mar 21, 2012 | 11:56 AM
LilSki's Avatar
Car: 85 Trans Am
I can get that when I pull it back out to weld it permanently.
Old Mar 25, 2012 | 07:44 PM
LilSki's Avatar
Car: 85 Trans Am
Had the pedal out today and took some quick measurements. Stock looks to be around 2" and after the pivot I have it around 1 1/2". There may be an issue for some with contact with the pedal bracket with the pedal all the way up. I had to shave a small amount off for clearance.
Old Oct 17, 2012 | 09:02 PM
nickdiesel's Avatar
Car: 1988 Camaro Convertible
Any updates on how this turned out seems to be the easiest way to get around this problem. I may jusr do this if all is well with yours thanks
Old Oct 17, 2012 | 09:33 PM
LilSki's Avatar
Car: 85 Trans Am
with about 6000 miles since this mod I have had no issues. I did fine tune the position a bit when I first did it. With it all the way up you had to go almost all the way to the floor to release fully which I didn't like. So I rotated it down a little at a time until when it was all the way to the floor the clutch fork just barely starts to hit the pressure plate. But while driving I almost never depress the clutch more than half way.
Every car will be a little different and may need more or less adjustment. That is what I liked about this mod is you get the adjustability of an adjustable master without paying for one.
Old Feb 3, 2013 | 07:32 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Where does this engage the clutch, is it almost all the way out like it was with the pedal stock?
I have been working on a "fix" to get the clutch to engage exactly like a 4th gen will, and have come to the realization you actually need to move the pivot (for the MC) out a little to accomplish this.
Old Feb 3, 2013 | 06:24 PM
LilSki's Avatar
Car: 85 Trans Am
You can set it any way you want. You can have it so far that it grabs just off the floor or all the way up and anywhere in the middle. I have fiddled with mine some since this thread and it is fully released just past half way and no contact with pressure plate at full pedal.
Old Feb 3, 2013 | 07:43 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
I understand what you are saying, however, having a "sweeping" adjustable one like yours, doesnt your master cylinder become out of line?
What I am thinking of doing to prevent that is lengthen the pin in the x and y axis (away from the firewall and toward the dash so as to keep the geometry with the MC true while also lowering the engage point.
Old Feb 3, 2013 | 08:01 PM
LilSki's Avatar
Car: 85 Trans Am
The master does not have to be in perfect alignment. In fact in many factory setups they are slightly out of line. The ball socket in the master can deal with a pretty steep angle. As for my setup the added angle has not seemed to have any ill effect on the master. I can take a picture to show what it looks like.
As for moving the pivot back you don't have alot of room to move it back without modifying the pedal bracket. As the stopper for the pedal will be in the way.
Old Feb 3, 2013 | 08:12 PM
LilSki's Avatar
Car: 85 Trans Am
Just took some quick pictures. Should give you a good idea of how straight it actually is.
Hope that helps!
Old Feb 3, 2013 | 08:45 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Thanks, it helps out.
When i said "pivot" i meant the one that the master cylinder mounts attaches too. NOT the pivot that mounts the whole pedal to the bracket.
Here is what Im working on.
I found out that between the 4th gen and 3rd gen pedals, the difference between where they engage is 1 5/8". I made a jig that allowed me to figure out where to mount the MC pin if I wanted the 3rd gen clutch pedal to be fully out 1 5/8" sooner. Here are some pictures since it is easier to explane that way.
diff between 3rd and 4th gen pedals
pin at stock position
pin at 1 5/8" sooner
If the pin is moved this distance, you have less "throw" on the MC therefore an earlier engagement and no chance of "over extending" the slave.
Old Feb 3, 2013 | 09:28 PM
LilSki's Avatar
Car: 85 Trans Am
I knew what you meant about the pivot I guess I didn't explain it well on my part. What I meant was when the pedal is at rest it comes back to a rubber stopper that the welded on extension rests against (see last picture of my first post). So if you were to say cut it off and move it back you would essentially move the pedal further forward and possible negating some of the change.
In the end I believe what you are proposing will work just as well. And I believe both methods essentially accomplish the same thing. I just liked the ability to adjust it with the pivot. And I have found no need to weld it as it does not move.
Old Feb 3, 2013 | 10:16 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Thanks for the info, i forgot about the stopper, i will have to keep that in mind when i do my mod.
I guess you and i were trying to acomplish the same thing, but by different methods, the goal is to shorten the radius of the arc from the main pivot to the mc pin.
Old Feb 11, 2013 | 07:27 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Just a quick question, when you said 4th gen pedals did it mean 94-97 or 98-02 or 94-02
Old Feb 11, 2013 | 07:37 AM
LilSki's Avatar
Car: 85 Trans Am
I believe they are the same 94-02
Old Feb 11, 2013 | 04:37 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Yes, as far as I know they are all the same. When I said 4th gen I was talking 95 specifically. Thats the year car the pedal set I have came out of.
Old Feb 11, 2013 | 06:44 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Thank you for answering my question so quick
Old Feb 13, 2013 | 11:29 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Another option you could do is to make the rod on the master adjustable. I went to the hardware store and got I believe a 3/8 coupler and a couple nuts. I already had a tap and die set. Cut a small piece out of the rod, but making sure with the coupler its about the same length. Thread both ends and put on the nuts and coupler. The coupler acts as the adjuster. I got mine to act great. The only complaint I would have is that is does release a bit high for my tastes, about in the middle.
Old Mar 30, 2014 | 04:46 PM
nickdiesel's Avatar
Are you using the stock master from the T 5 or a 4th gen master liniski?
Old Mar 30, 2014 | 05:53 PM
LilSki's Avatar
Car: 85 Trans Am
The master and slave are both 4th gen.
Old Mar 30, 2014 | 06:02 PM
nickdiesel's Avatar
Thanks bud
Old Aug 17, 2014 | 12:30 PM
nickdiesel's Avatar
When you said moved it down a little bit to fine tune it to say 1 5/8" -1 3/4"center to center.Doing the mod today and just wanna be as close as possible if I could thanks
camaro1185
Oct 26, 2015 06:51 AM
Denricci22
Sep 18, 2015 09:02 AM
mygta87
Sep 14, 2015 10:36 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
