TPI throttle linkage correct for 2004R/700r4
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
Does the stock throttle linkage on a TPI Camaro has the correct arc and "pull" for proper TV cable operation on the above transmissions or is an adapter needed like using one of those transmissions with a non-QJet carb?
Car: `86 SS / `87 SS
Re: TPI throttle linkage correct for 2004R/700r4
The TPI TV cables in the F-bodies and Corvette were matched to the 700-R4. So it's absolutely correct.
The 200-4R uses the same TV cable "pull" distance and cable housing fitment as the 700-R4.
Use the TPI cable with a TPI throttle body, the TBI cable with the TBI throttle body and the Q-jet cable with the Q-jet.
Car: 1969 Camaro SS
Transmission: 200r4
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
