Park/lock control cable help
Old Sep 10, 2014 | 06:41 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 5 speed manuel
Axle/Gears: 3.08
Ok this is the situation I'm swapping from a manual transmission to a automatic and I need help with the park/lock control cable that goes from the auto shifter assembly to the steering column on a automatic. My question is how would I run the cable on a car that was a manual car. Would I have to swap steering columns or run a aftermarket cable? If anyone has done this before I would greatly appreciate any help.
Old Sep 11, 2014 | 05:32 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Park/lock control cable help
I'm doing the same swap, With the manual column the lock cable isn't needed. Just throw it to the side and move on......
Old Sep 11, 2014 | 03:27 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Thanks Restrorob, I might hit you up if I have some more questions since your doing the same swap.
Old Sep 11, 2014 | 05:49 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Even with the Megashifter I installed last year the instructions had you fix that cable in a permanent spot and leave it disconnected. Be mindful that you can start the car in any gear after that :O
Old Sep 11, 2014 | 07:41 PM
Restrorob's Avatar
Car: 88 GTA
Is that not a neutral safety switch on the side of the factory auto shifter you can run the clutch pedal switch wires too ?
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
