TCC test?
TCC test?
Ive Searched and searched to no avail.
I need to know the test port on the obd port to make the TCC lock.
Trying to figure out if my switch died before dropping the tranny to check my other worry.
Worked fine before restoration started.
Thinking some over spray got into the connector while painting the trans.If so,any ideas how to get it cleaned out without damaging the plastic of the connector,and without dropping the trans to get down inside that connector?
Car: check
Engine: check
Transmission: check
Re: TCC test?
Try terminal F, it could possibly be terminal C. I see both listed for a '92 dependent upon which engine the car came with.
RBob.
RBob.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: TCC test?
I believe the wire you need to ground to override the TCC is tan with a black stripe.
RedLeader289
May 28, 2019 01:47 PM
