Trans. Help
Old Oct 1, 2014 | 05:58 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Trans. Help
Hi Iam running a 700r4 87 iroc today I took it out an it shifts fast threw the gears its like 123 in no time does someone know what could be the problem?
Old Oct 2, 2014 | 07:33 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Trans. Help
I'm no expert , but , if it were mine I'd be making sure the transmission's Throttle Position Cable is still attached properly to the throttle linkage .
Lots of folks mistake this for "Isn't it just a kickdown cable" and NO , it's far more than just in control of passing gear kickdowns , it controls shift points in relation to throttle position . If the plastic attachment is broken and the cable is not moving with the throttle , it will go through the gears as though your barely stepping on the gas even when your much further into the gas pedal . This is known to fry these transmissions since it ALSO controls "line pressure" and the clutches are not as firmly engaged at the lower pressure resultant from a broken/improperly adjusted cable .
Good Luck with it ....
83RDRACR
Mar 26, 2016 08:13 PM
92projectcamaro
Dec 8, 2015 12:25 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
