t5 flywheel question
Old Oct 8, 2014 | 09:18 AM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
about to fit a new clutch but flywheel looked non to clever so have a new one here to go on.
just removed the old one and it has a spacer/shim behind it.
should this be there or do i bin it and bolt the new flywheel to the crank
not sure if it there from the factory
help please dont want to fit it wrong and pull the trans again
Old Oct 8, 2014 | 04:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t5 flywheel question
In the third gen T5 setup it is used to make a used machined-surface flywheel the same thickness as new for the sake of clutch mechanism geometry. Personally, I have had used machined flywheels work just fine without the shim. In your case with new flywheel, you will leave it out.
Old Oct 16, 2014 | 11:31 AM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
all fitted.
my gearshifting is now transformed
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
