T5 Noise
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
T5 Noise
As the title says, my T5 just started making noise the other day. Noticed it all of a sudden, returning home after a 3 hour drive. It sounds like gear whine, very high pitched, and it happens in gears 1-3. It gets higher when engine RPM increases, and does not make the noise when not in gear. There is also a quick whine-ish noise while shifting from 1-2, and 2-3. The clutch is not slipping at all, and everything else is functioning normally. Any ideas as to what the noise is? My bird is my daily driver, so is this something major?
Car: `86 SS / `87 SS
Re: T5 Noise
Check the fluid level / change it. Plan on bearings, though the countershaft bearing location in the case may be wallowed.
Re: T5 Noise
Yup, that'll be the countergear bearings...
You've let it run dry. If the leak is the front countergear bearing, down low on the pass side of the surface of the trans where it meets the bell housing, there's no repairing it. Start looking for a T-56. Meanwhile keep PLENTY of gear lube close at hand; check it every coupla days.
Car: 1986 Trans Am
Re: T5 Noise
Well that's not good. As a full time college student, a T-56 is not in the cards anytime in the near future. Those things are still going for crazy money.
Sofa, when you say gear lube, is that different than transmission fluid?
Re: T5 Noise
Yes.
It's something in the range of 75W-90 oil (THICK), with a high-sulfur (stinks like hellfire) additive for extreme contact pressure.
Conveniently available at most any parts store.
I recommend THE BEST you can easily get, keeping in mind that it'll all leak out anyway, so you don't want to spend giga$$$$ on it; won't keep the trans from wiping out terminally, but may prolong the final event somewhat. I usually use Mobil1.
Re: T5 Noise
Hard to tell; could be tomorrow, could be a year.
Keep it full of fluid to extend it as long as possible. They go QUICK when they run dry.
sjorgens
Oct 1, 2015 07:54 PM
