TH400 Mounting Points
Old Oct 30, 2014 | 06:02 PM
cycleguy04's Avatar
Car: 1983 Z28
Engine: life is more nifty with a chevy 350
Transmission: TH400
Axle/Gears: 10 bolt, unknown gears
Are all the TH400 to cross member mounting points the same? The cross members available for thirgens to adapt a TH400 say they need to be short shaft. If I got a long shaft and swapped it out for a short shaft I wouldn't want to run into a problem where the mounting points on the case are different and it wouldn't work.
Old Oct 31, 2014 | 12:13 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: TH400 Mounting Points
Yes they are different.
Th-400 short shaft face to mount is 26-3/4"
TH-400 long shaft face to mount is 28"
Overall length is 26-3/4" on short shaft, and 34" on long shaft .
So no, you can not do as you planned, you will run into mount probs. I guess you could weld a plate steel tab to crossmember and drill new hole, but will still have torque arm mount trouble.
If the crossmember/kit mounts TQ arm to tailshaft it will not work, if crossmember has TQ arm mounted to it the longer trans may hit mount point or TQ arm
Old Oct 31, 2014 | 07:04 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
you might find good info in this link;
http://www.maliburacing.com/auto_tranny_id.htm
i could be wrong, but i thought the tranny mount doesnt change no matter what tailhousing you use?
Old Oct 31, 2014 | 02:21 PM
Car: 1988 Camaro
On some they do and some they don't. TH-350 long and short tail has the mount in the same place, but the th-400 does not
Old Oct 31, 2014 | 05:37 PM
cycleguy04's Avatar
Car: 1983 Z28
Transmission: TH400
Thanks for the info guys, but I found a short shaft tranny. I should be good to go.
redmaroz
Apr 25, 2017 07:14 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Elliswon
Aug 10, 2015 12:33 PM
