Steering play: new coupling assembly?
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hi guys,
I'm going to buy some new parts to solve my steering play. I would like to ask you if you think that a new steering coupling assembly is fundamental as far as the play/loose is concerned.
Because of shipping, it costs me more than the other pieces :/
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Steering play: new coupling assembly?
that is often called a "rag joint"-you can observe the rag joint while someone moves the steering wheel to see if it has loosend up and causing steering play(plastic steering shaft guard will need unclipped and moved for a good view)IF the rag joint needs replaced,it is sometimes replaced with the steering shaft from a ~1997 chevy astro van shaft as an upgrade to needle bearing "u-joints"from the rag joint.IIRC, certain jeep steering shafts can also work.
Engine: 5700cc
I've read in the net that rag joint is pretty old and no usend anymore in cars since many years, and yes, it causes steering play.
That's interesting, that is, replacing a shaft with rag joint with a u-joint shaft. Could you be more precise? Is it a complex procedure? What parts will I need?
thanks!!
thanks!!
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
https://www.thirdgen.org/forums/susp...ing-shaft.html
although James had some issues with his, I've several miles on mine.
a leaky input plug at the steering box will kill a rag joint fast. double check your's is dry or install a shaft seal. pretty simple procedure.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I had a worn rag joint and after replacing it, was very surprised how much tighter my steering was. I did this repair on my 83 Camaro.
Engine: 5700cc
THANKS!
Check the front seal on your gear box to ensure it is not leaking.
Engine: 5700cc
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The rag joint is sometimes loose, but most if the okay is probably in the box.
It can be determined clearly by observing the system while someone moves the steering wheel.
Your box is clearly leaking at the pitman shaft, rebuild the whole thing while its out.
You need an inch-lb torque wrench to do it properly.
Engine: 5700cc
Yeah, we rapidly tested it.
Here some pictures of my rag joint. Mechanic said is it fine right now:
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Sorry for the typos earlier.
Rag joint looks fine.
This type of steering gear always develops play over time. Rebuilding is not too hard. A little tedious and it does require special tools. Once you do one of them, they get a lot faster the next time.
Don't bother adjusting the over center, that NEVER helps.
Engine: 5700cc
I dont wanna rebuild. I'm just going to put a new gearbox.
What do you mean with "adjust the over center" ?
thanks
It seems that most if the rebuilt gearboxes aren't built very well. I would take any rebuilt box and check the torque settings. Might as well rebuild the one you have.
The over center adj is the nut on top of the box. The tension is set properly by measuring the torque on the input shaft. Has to be disconnected from everything else.
Many people just tighten it to try and fix the box play. Usually just makes the car wander more when done in the car.
Engine: 5700cc
Any suggestion for my mechanic?
The "new" gear box will be rebuilt. All depends who rebuilds it. I would check and reset as necessary the torque specs on the input shaft and pitman shaft. These require a good inch pound dial indicated torque wrench. Factory service manual has the specs.
Engine: 5700cc
I just bought the new ACDelco steering gear from rockauto.com. I hope it will be already tuned and fine
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
Night rider327
Sep 2, 2015 04:17 AM
