fluid exhange
Car: 1992 RS camaro
Engine: 5.0-305
Transmission: Automatic
fluid exhange
Hello all! Need some advice the previous owner of my 1992 rs 305 camaro bypassed the transmission cooler by cutting the pressure and return hoses and connecting them together, this resulted in some terribly black burnt transmission fluid, so in response to this I am preparing to have the transmission rebuilt but for the time being I'm replacing the lines, fluid, filter, and gasket. And I was just in a dillemma as to if I should change out the 5 quarts of fluid in the pan, or should I just completely flush the system with 11.5 quarts of new fluid?
I've had someone tell me to do 3.5 quarts new fluid and 1.5 quarts old fluid (reminder my fluid is burnt) put about 400-500 miles on it then repeat that exact process, everyone is telling me something different and I need help! Thanks for your response
Re: fluid exhange
If the fluid is destroyed, you need to get EVERY SINGLE DROP POSSIBLE out of it.
Don't expect miracles: the reason the fluid is black is because THE PARTS got so hot inside there, they burned it up; all the rubber seals and such are probably crumbled to dust, and likely the clutches are ruined too.
The pan holds around 5 quarts or so. Another quart or thereabouts is in the various places inside the trans that it goes; clutch pistons, accumulators, etc. The rest is in the torque converter and cannot be "drained". Only way to get it out is to run the car with the cooler lines disconnected, catch the old fluid as it is forced through the converter and out the one cooler line (5 gallon bucket under the line or the like), and keep pouring new fluid into the fill tube to replace what is expelled.
Frankly though I think you're wasting your time money and effort on a hopeless cause, but, good luck with that.
Car: 1992 RS camaro
Engine: 5.0-305
Re: fluid exhange
Car: 1988 Camaro
Re: fluid exhange
Yep... The ATF is not black cause it's burnt.. It's black cause the clutches (frictions) in trans is burnt and wearing. The black you see if your clutches.
You can not run an auto trans with out a cooler.
If you drop the pan you will see thick black goop in bottom of pan with shiny specs in it.
Your best bet is to have trans rebuilt, replace torque converter, and flush the lines out
Car: 1992 RS camaro
Engine: 5.0-305
Re: fluid exhange
Re: fluid exhange
Car: 1984 &1987 Firebird, 1991 GTA
Engine: 5.0(84) , 5.7L LT1 (87),5.0(91)
Axle/Gears: 3.23;3.42;2.73
Re: fluid exhange
Busy rebuilding the TH 700r4 on my 1984 - what fluid did you use? Do I have to use stock ATF, or can I upgrade to Dexron 3?
Car: 1988 Camaro
Re: fluid exhange
All dexron/mercon is backwards convertible.
So if your trans uses say dextron II, you can use dex III and work great... But if your trans uses dex III, you can't use dex II in it.
You will be fine with any dexron/mercon sold in the stores. All of it will work with your 700r4.
HoosierinWA
Oct 7, 2015 10:15 AM
