1988-1995 t5
Old Jan 30, 2015 | 03:56 PM
greasyfox18's Avatar
Car: 1986 firebird
1988-1995 t5
Ok guys new here but i found a wc t5 with the casting number 13-52-066-936 which to my knowledge is from a 88-95 fbody correct? Will it work with a v8 bell housing. Or is it the ones that had the ford pattern case?
Old Jan 30, 2015 | 04:39 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: 1988-1995 t5
Thats the casting number.
If it still has a metal tag attached to one of the bolts it will show what it came out of.
You can decode that tag here:
http://www.britishv8.org/articles/bo...t5-id-tags.htm
Old Jan 30, 2015 | 05:02 PM
Car: 1986 firebird
Re: 1988-1995 t5
It doesnt have a tag
Old Jan 30, 2015 | 06:57 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 1988-1995 t5
If it is a tilted trans. mount pad on the tailhosuong casting, it is F-body.
AND If the VSS points right at the output shaft, it is 4th gen V6.
Anything 26 spline input is either 4th gen V6 or third.gen 305.
You can Google pics of Ford T5 and Muncie pattern and figure out the front of the case pattern. The third gens all were Muncie pattern.
Old Jan 30, 2015 | 07:50 PM
Car: 1986 firebird
Re: 1988-1995 t5
Its a ford pattern no ears on the case. So can i swap the wc internals from it to a third gen case and use the tailshaft and stuff as long as the case i have is a wc?
Old Jan 30, 2015 | 09:30 PM
jmd's Avatar
jmd
Re: 1988-1995 t5
Yes you can. Watch out for input length differences.
Raz
Aug 21, 2010 12:21 PM
Raz
Jun 22, 2010 06:18 PM
ThraxXx
Jan 9, 2004 07:33 PM
welch
Apr 30, 2003 11:25 AM
